Drag Racing Tech - Launching Technique
Camaro Ryder KV
10-18-2006, 01:24 AM
I have a stock 01 ss with a loudmouth 1 exhaust, how do i hook em off the line? burnout first? floor it, half down??????
thunderstruck
10-18-2006, 08:37 AM
if you are on radial street tires there is no need to do a burnout, just spin them a little to clean the crap off of them.
and its gonna take some experimenting with your launch, alot depends on how sticky the track is.
CamTom12
10-18-2006, 08:46 AM
your best bet's going to be by riding the clutch at a higher rpm until your gear is fully engaged. I'd start at 4k - 4.5k
Camaro Ryder KV
10-18-2006, 10:09 AM
i have an a4, and i have goodyear eagle f1 gs
prostock_bigblock
10-18-2006, 10:54 AM
just clean them with a tiny burnout and step on the line and step on the brakes and raise the rpm at 1500 rpm.
I shift it manually starting with first gear till 3rd gear and dont shift to overdrive if u dont have gears.
Magnet
10-18-2006, 11:30 AM
i have always heard nto to shift an auto manually because its both hard on the tranny and also slower shifts=slower time just my .02
prostock_bigblock
10-18-2006, 04:14 PM
it seems to work with me on my old 98 A4 very fine and had better times with manually shifting it.
putting it in 3rd gear all the way to the finish line is another way to do it to.
CamTom12
10-18-2006, 04:16 PM
Here's some advice I got from a buddy on launching the A4's
Launch in 1, because it has not only the 1st gear clutches but the manual clutches engaged, helps the tranny hold up. Immediately after the launch pop it into D
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
