Car won't start!!!
Car won't start!!!
Well I get up to go to work this morning and the car won't start. I have had it about two years with no problems. About a year ago I did put in a Red top optima. I turned the key to on and everything is bright and normal. You turn it to start and no starter clicking or anything. I do hear something under the hood, I imagine its the ign relay. Any ideas, I'm thinking the sercurity crap or maybe the actual starter???
Well here's the latest development.......I read in the manual about the sercurtiy light (in the guages). When I try to start the car the light flashes on and off and when I go back to on after it not starting it continues to flash. The manual says the key is dirty or may be faulty. Its to bad I'm far away from my second set of keys. I'll try the dealership and see what happens.
It's very possibble that one of the wires that is in your ignition switch has broken. If that's the case you have 2 choices: Go to dealer and purchase new ignition cylinder and two new keys, or if you can just turn off VATS.
And by reprograming you mean holding the lock and unlock buttons down at the same time???? I tried that this morning with no luck. I got the reistors i need and I'm about to try that.........i did take an ohm meter to the connecter under the dash and got an open so we'll see
So i got the resistors rigged in and it works.......................................I'm out of town now but i'm going to get a new ignition cylinder when i get back home. Thanks for all the help.
