Clutch Master Cylinder
Does the clutch master cylinder normally stay in the all the way disengaged state? It was pulled out of the car and I'm assuiming that it's still in the poistion of the clutch being disengaged. Just checking to make sure before I go and start to mock it up.
I assume the line, still all stock GM right now, needs to be hooked up to transmission to allow me to push the cylinder in any?
From what I've read it's a 7/8" stroke and the cylinder will allow the rod to travel 1" so I hope that is correct.
Thanks!
Thanks!
Yes if it has no air in it. You can also press the end in to let fluid out. Thanks Steve.
Originally Posted by stealth71
It is a 1"x3/4" stroke, but you don't really want to be hitting either end of the stroke so 7/8" is what most set it up for.
When you say 1"x3/4" stroke do you mean it has a useable range of 3/4" to that of 1"? Sorry, don't understand what 1"x3/4" means.
