i need more fuel then Racetronix+BAP gives, what are my options?
im goign to tune my car for about 600-630RWHP, i already have a racetronix intank installed and a BAP. the last thing i want is to run out of fuel on dyno day and im not sure the Racetronix and BAP can handle 600RWHP on a FI car, what are my choices? i really dont want to have to switch out my brand new racetronix intank for a dual....... what else can i do? is an inline pump possible? what other choices do i have??
Really the only other option short of a complete fuel system, is another pump in the tank. We have seen 2 pumps in-tank with BAP on one of them is good for 650rwhp. That is putting a set of 60lbs @ 100% duty on a FI car.
The next step up is a total fuel system, not cheap but good for double what you need it for most of the time.
LS1TECH Sponsor
Originally Posted by 2002/Black/SS
is there any way i can add a pump in the tank without messing with my already installed racetronix? or is that impossible? also as another point is 600rwhp possible with my stock fuel rails and lines?
You should consider a rail mounted FPR to stabilize your fuel pressure @ the rail.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
>WEB SITE<
I've got the racetronix intanke and the vortec-inline, with the stock fuel rails. I'm putting down 600 to the rear on a conservative tune. Im choking the hek outta the system with the 42lbr's go 60's if you can. I just changed my plugs and no signs of detonation or other problems. Hope this helps.
Im custom building my fuel system so I know Im not going to run out of fuel, 1/2 inch fitting welded in the bottom of my factory tank, 12an line running to the filter and down to the aeromotive 111001 pump, 1/2 inch Alu line running up into my fender and 8 an under the hood running to the rails, 8an return to the aeromotive regulator and 3/8 return back to the tank
