Rear main Seal
yea, once you take the tranny and stuff out (which isnt terribly difficulty assuming you have a lift or something) then its a piece of cake, just ubolt the back of the oil pan and inbolt the thing surrounding the rear main seal, then install the new one
Originally Posted by the_merv
It has to be done with the Trans removed, no question about it. You have to unbolt your Flexplate/Flywheel to get to it.
The next question is if it's installed wet or dry..
I am doing this today so I just read it after opening both boxes at the store.
JD
