Midwestern Members IA, IL, IN , KY, MI, MN, MO, NE, OH, WI, KS, OK
How do u clean a Tapper for a Keg?
Old 10-21-2006, 06:51 PM
Silver 00 SS's Avatar
Default How do u clean a Tapper for a Keg?
I know this has nothing to do with cars but does any one know?
Scott
Old 10-21-2006, 07:46 PM
SpaZMaN's Avatar
use water. if you REALLY need 2, use a VERY small amount of dish soap
Old 10-21-2006, 08:05 PM
yak
yak's Avatar
yup i usually go out to my garage after rinsing in and blow the bottom fitting out with a air hose to try to dry it out.
Old 10-21-2006, 08:35 PM
Moderator
FANTAZ28's Avatar
HOT WATER!!! fill up your sink with real hot water and pump it out using the tapper
Old 10-21-2006, 08:38 PM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
yep yep
Old 10-21-2006, 09:24 PM
FLT
FLT's Avatar
I've always used cold german beer but I guess the pumping hot water through it works well to!
Old 10-22-2006, 12:03 AM
Retired Street Racer
Matt D's Avatar
Did you get my PM bro?
Old 10-22-2006, 01:56 PM
liqour enthusiest
88monte's Avatar
fill the sink up put a drop of dish soap in warm water, pump it threw the tap. drain the sink and fill up up with really hot water and pump it til it comes out clean and not soapy. its not hard. a lot of people forget to clean the tap out and you can actually get really sick from a dirty tap. i learned that the hard way
