The Build Begins!!!
The Build Begins!!!
Dropped the car off at my buddies shop RPM last night to get started on it. I CANT WAIT so excited, it should be a monster
HPE 408 Iron Block Built by Erik
~Eagle Crank
~Callies Compstar rods
~Custom Weisco Pistons
~Compression is about 8.5 to 1
Custom 238/238 Duration Cam spec'd by Erik
Stage 3 ETP Heads
Carb Style Manifold
Nasty Performance Complete Fuel System and Tank
Nasty Performance Valve Covers
Mcleod Twin Disk
Force Fed Fabrication Single Turbo Kit w/Precision T88
Moser 9" 35 Spline axle's Gundrilled w/ 3.70 gears
HAL QA1 Shocks and Springs
Denny's Nitrous Ready Driveshaft
BMR Chassis Upgrades
~BMR K-Member
~BMR Torque Arm
~BMR Panhard Rod
~BMR Weld on subframe connectors
~BMR Upper A-Arms
~BMR Lower Control Arms
RPM Fully Built 6 Speed cryoed and micropolished
Still debating the exhaust setup, me and my buddy fran are probably going to do a custom 4" Downpipe and dump it before the axle...dont know what muffler to pick though. Fran feel free to chime in if i am forgetting anything or if ya want to add something.
Probably forgetting some stuff ill update the list when i get home. Should be a blast to drive. Pics coming soon
~Eagle Crank
Stage 3 ETP Heads
Carb Style Manifold
Mcleod Twin Disk
~BMR K-Member
~BMR Torque Arm
~BMR Panhard Rod
~BMR Upper A-Arms
LS1Tech Sponsor
Set up looks stout.. Any info on the turbo set up itself?
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Definately looks like a strong setup, im going through the same thing myself. The suspension and Tranny has already been done, engine is out (LS2 block) waiting on the Turbo kit to show up along with Fuel upgade along with new Cam, Rings, Crank, rods, etc. Do you think the Stage 3 ETP heads are the best? do you know anything about RHS Heads? I guess there a rebuilt ETP head from what I have been told? This is what the guy that is building my car suggests for good FI heads. Also what are the specs of the cam that you are going to be running? Are you going to be keeping your Air Conditioning? I will be running a S-85 Turbo. I ask this because your setup looks really similar to what I am doing. With that compression, how much boost do you plan on running? Do you plan on running on pump gas? How much rwhp are you going for?
That setup looks definately capable of hitting 800rwhp on pump gas. Must be nice not having to have AC, it is a must where I am at, but thanks to a good OFI Turbo kit, it will allow me to keep it. Keep us posted on the build and look forward to pics.
~Eagle Crank
Stage 3 ETP Heads
Carb Style Manifold
Nasty Performance Fuel System and Tank
Mcleod Twin Disk
~BMR K-Member
~BMR Torque Arm
~BMR Panhard Rod
~BMR Upper A-Arms
~Eagle Crank
Stage 3 ETP Heads
Carb Style Manifold
Mcleod Twin Disk
~BMR K-Member
~BMR Torque Arm
~BMR Panhard Rod
~BMR Upper A-Arms
If your not running bs3 or a convertor box, biggest inj's you can run from what I know is 75#ers, which is what im running right now. I was at 89% DC on my 101 oct setting and made 933 rwhp, so unless you dont care about having a higher duty cycle, chances are you wont make that power due to lack of fuel.
were gonna run a convertor box.... we have 83# injectors....
What specifically is included in the Nasty Fuel System? Did you get the specs to the Cam yet?
As for the Cam i havent found out the lift yet its a 238/238 on a 115+4 i just have been busy sorry i didnt forget though, i will try and find out wed/thur cause thats when i have off from work. Yea i know, i have weird work days lol.
Man your car is going to fly. Is the fuel system kit the Stage 2 Race/Street kit-up to 2000hp (1400+rwhp) at http://www.nastyperformance.com/FuelSystems.html
Originally Posted by TrakDay
Sounds alot like my setup... except I am going twins. 9:1 comp. Good Luck man... Erik built my motor too!
Now we know now.
looks like you're going towards a race car now that is streetable. why not try the 4l80e and have overdrive?
at the cost you're spending its only a couple grand more, what's money right?
Originally Posted by Got Me SOM
was wondering why you were ditching the F1 set up.
Now we know now.
Now we know now.
