ATTN: Detailing Xperts: Follow up to Compound Polish?
Swirls here. I've heard some good things about Meguiars no. 80... I was wondering if this plan would fit well:
1. Dawn wash, claybar, dry.
2. PC: Orange pad with Meguiars no. 80 Cutting Polish
3. PC: White pad with ???
4. Meguiars no.7 Finishing Polish/Glaze by hand or grey pad
5. Meguiars no. 26 Hi-Tech wax or NXT Sealant ??? by hand
First question: What would be a good follow-up, finishing polish, to the no. 80 to leave the paint smooth and free of ANY micromarring with the white pad? I'm trying to stick with the Meg's line. What's a good finisher here at this point with the white pad?
Second question: After all this hard work (I'm looking at two or three days straight here), would it be foolish to seal it in with a carnauba wax (durability concern)? Would I be better off using NXT to seal it in better? No. 26 looks so damn great, but I want the hard work to be adequately sealed, cured, and protected. Thanks fellas.
As far as I know, Meguiar's #80 is not cutting polish, but the speed glaze. It's a popular follow-up product to use with Meguiar's DACP (#83). The #83/80 combo is very popular and easy to use, and addresses up to moderate scratching. I suggest setting up your cutting step to go with #83 instead of #80 with the same pad, and set a light/no abrasive pad up with #80 as a finisher. Colors are different for every pad manufacturer, but if I'm not mistaken, the white pad tends to be the finishing pad. Opt for a light abrasive pad if it doesn't clean up the haze you may get from #83.
I can't speak to sealing products because I stray from Meguiar's when it comes to that step. For durability, go ahead and go for the sealant. Waxes are relatively high-maintenance and need frequent touch-ups. The exception being Collinite of course, but that isn't a Meguiar's product.
Originally Posted by bboyferal
Thanks... Reason the above plan has no. 80 paired with the orange pad is that I've heard no. 83 is a borderline rotary buffer product... Effective, but hard to breakdown with a Porter Cable. Any more thoughts?
Good luck!
