96# Injectors... Good for?
I have a set of 96# injectors I was planning on using with a Versafueler on an F1C Procharger setup. I changed my mind and will now be going TT and using BS3.
Anyways what kind of max HP level would I see out of the 96# injectors at 90% DC? rough estimates? Or should I plan on stepping up to 160# injectors? 1200+rwhp is the goal.
Thanks
Thanks
Originally Posted by Old Geezer
not going to take you to the 1200RWHP.
The calcs show about 124PPH is going to be what you need.
I'd go w/ the 160's. Buy in a matched set, ONLY!!
And yeah I will make sure they are matched. I will probably just order them from Stenod.
