Rod Bolt Upgrade
Rod Bolt Upgrade
I know about the Katech bolts and Lingenfelter sells a set also. Both of these are supposed to be a direct replacement but what about the ARP ones?
Can they be installed in the same manner that the Katech or Lingenfelter bolts are?
I put ARP's in my motor w/o resizing the rods and it went well. I already had my motor out and on a stand so I just flipped it over and did them. Make sure you use the thread lube they supply for torqueing the bolts.
I used the ARP bolts as well and no problems here. Read this link....
https://ls1tech.com/forums/showthrea...=423651&page=2
