TONS of SES codes help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
Old 10-22-2006, 11:34 PM
forsale2's Avatar
Exclamation TONS of SES codes help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
heres what they are, car ran for under 2mins in park and these are the codes i got on datamaster, the car runs so bad, its not the pcm nor any of the sensers, everything is pointing to the electrical side of things
MALF 78: Fan 2 Fault ,
MALF 16: Lo-Res Fail ,
MALF 67: A/C Press Sensor Degraded ,
MALF 84: 3-2 Downshift Feedback Fault ,
MALF 97: 4000 PPM VSS Circuit Fault ,
MALF 55: Fuel System Lean ,
MALF 24: Output Speed Low ,
MALF 29: EAS Electrical Fault ,
MALF 64: Right O2 Lean ,
MALF 37: Brake Switch Stuck On ,
MALF 52: Oil Temp Low ,
MALF 41: EST Open ,
MALF 27: EGR Electrical Fault ,
MALF 13: Left O2 Fail ,
MALF 82: Shift A Solonoid Fault ,
MALF 95: Oil Life Lamp Circuit Fault ,
MALF 63: Right O2 Fail ,
MALF 80: Transmission Component Slipping ,
MALF 22: TPS Low ,
MALF 50: System Voltage Low ,
MALF 25: MAT High ,
MALF 71: A/C Evap Sensor Failed ,
MALF 12: No DRP Pulses ,
MALF 81: Shift B Solonoid Fault ,
MALF 53: System Voltage High ,
MALF 22: TPS Low ,
im guessing this is something electrical, any clue?
Old 10-22-2006, 11:43 PM
PunishedU's Avatar
I hope that there is something wrong electrically for your sake. Otherwise, that is a lot of crap to replace. I just had like 5 or 6 codes show up at once and i thought that was a lot.
Old 10-23-2006, 12:48 AM
Hot94Z28's Avatar
Bad Ground?
Old 10-23-2006, 01:38 PM
carzman5678's Avatar
WTF? I see system voltage low. Check your power wires and ground wires. Also check the battery voltage, make sure the PCM hasnt got wet.
Old 10-23-2006, 01:48 PM
burnzilla's Avatar
Yes, but some of them have nothing to do with electrical...although the sensors send data electrically to the PCM.
I think you might have a major short, or loss or power somewhere after your battery/alternator.
It might be triggering a shitload of sensors, or throwing them off.
Does the car run?
When did it start doing this?
Maybe a rodent got in there deep and chewed some wires?
Old 10-23-2006, 07:06 PM
forsale2's Avatar
Does the car run?
the car runs but not really that well, it ran geart before but the water pump was wining so i wanted to get to that before it started leaking on the opti, i put on a new water pump and cap and rotor, and i triple check everything, during that time i tryed to read my pcm but it wouldnt read and after i was done with the water pump ect, started it up and it just runs like crap, not IAC not the maf not any of the sencers, not the plugs nore the wires, not the pcm eiether, at frist i thot it was the pcm, but i swaped in another one from the same car and same thing, i had the pcm bench tested and read, everythings fine with it, this is the most frustarating thing, almost everday im out there looking, i checked all the fuses ect ect,
Old 10-23-2006, 07:09 PM
Formula350's Avatar
What year car is this? If it's a 93 you can pull the chip and the car will run in "Limp Mode" which is really, running like TOTAL *** lol Literally, you limp it to where you need to go. I don't know what 94+ can do for close to the same thing
Old 10-23-2006, 07:13 PM
forsale2's Avatar
1994 z28, i have data logs of the car when it was running good and when i was done putting on the water pump etc, there for datamaster, if anyone wants to take a look
Old 10-23-2006, 07:51 PM
So this happened after you changed the water pump? If you scan the car, do they all come back? For the voltage issue, I have seen a really low battery make a car throw ABS codes because it didnt have enough power to operate the hydraulic unit.
Old 10-23-2006, 08:20 PM
396D1SS's Avatar
you need a WTF light
Old 10-23-2006, 08:59 PM
forsale2's Avatar
ya tell me about it, anyway i attached 2 datalogs of the day before i pulled and install the parts then after now running like crap
File Type: zip
File Type: zip
Old 10-24-2006, 02:44 AM
forsale2's Avatar
anyother ideas?
Old 10-24-2006, 04:27 PM
01WS6/tamu's Avatar
Check the grounds by the coil driver and on the side of the block by the dipstick tube. pull on the wires about an inch back fromt the ring terminal to see if the wire broke in the insulation. If not gm pcm's pull this **** when they frag.
Old 10-24-2006, 10:11 PM
forsale2's Avatar
Well, i took the TB off and cleaned the IAC and added a new gasket, when i took the TB gasket off was missing a peace, i can not believe that having a vacuum leak would throw all these codes, anyway after i put it all back i started it and it idled fine and ran great, confused so plugged in my data logger in and started to log, i now get constant a MALF 22: TPS Low code, and i see that my Lterm count is at 134 at idle and when in gear both L,term counts are 142 , 135 and those pretty much stayed the same the whole run, and the S,trem counts are around 108 - 128,
Old 10-25-2006, 12:02 AM
Make sure you plugged the TPS back in.
Old 10-25-2006, 01:05 AM
forsale2's Avatar
i checked its pluged in
Old 10-25-2006, 05:15 PM
forsale2's Avatar
i checked it on the data log, right when i turn the key on with out the engine running it thorws the low TPS code, but it sits at 0.61 volts 0.0% open, and i push the gas and the volts move up and so does the TP % , so whats going on?
Old 10-25-2006, 05:59 PM
FAD2BLK93's Avatar
When I uplugged the TPS it set a code, and the code stayed even after I plugged it back in, until I cleared the code.
Old 10-25-2006, 07:18 PM
forsale2's Avatar
how do you clear them?
Old 10-25-2006, 10:05 PM
Freescan can clear codes.
Quick Reply: TONS of SES codes help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
