How much should I mill my heads?
Old 10-23-2006, 11:51 PM
Slo_240sx's Avatar
Default How much should I mill my heads?
The search isnt working to great and when it did I really couldnt help find an answer.
I am rebuilding a 98 block/heads. I just got done hand porting the heads and am going to send them out to get milled. I am a little worried about PtV clearance.
Stock never been milled heads
Stock valves
-4cc Flycut Pistons
Futral F14 cam 232"/234" .598"/.598" 112LSA
.042 compressed headgaskets
I am thinking I should take .030 off the heads. Does that seem a bit much? I am shooting for stock compression to help make up for the flycut pistons. I also need a hand using Pat Kelly's compression calculator. I just want you guys to look it over so I do it right the first time around. Thanks in advance guys!
Old 10-23-2006, 11:52 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
.030 would probably be good for about 10.7-8:1 CR with that Futral cam. What kind of gaskets are you planning on using?
Old 10-23-2006, 11:53 PM
Xtnct00WS6's Avatar
Might want to take a look at this> https://ls1tech.com/forums/showpost....2&postcount=41
I think that if you mill .040 you'll be at 11:1 static compression. I'm going off of memory so you'll wanna double check my math. That does't account for the -4cc in the pistons though.
Old 10-23-2006, 11:57 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I was trying to figure for the relief. But mine might be off a bit.
Old 10-24-2006, 10:38 AM
Slo_240sx's Avatar
I am going to be using Mr gasket .042" compressed headgaskets. I am worried about PtV clearance more than anything else but still want to have the correct compression. I think I should be ok .030 on the mill job since its slightly smaller than a MS3 and people clear with stock heads. As long as I can clear with -4cc pistons, F14 cam and .042" gaskets I'll be happy. Milling is the last thing I need to do before the heads go back on. Thanks guys!
Old 10-24-2006, 11:47 AM
Sigforty's Avatar
.02 to .03 is what I would do.
Old 10-24-2006, 02:06 PM
Slo_240sx's Avatar
I just sent them out a hour ago. Asked for a .025 mill and to check for a valve job. Thanks guys.
