Another Cam ?
Another Cam ?
Whats a good cam to run on an LS1 with stock heads, and and LS6 intake...There will be a 3200 stall converter and transcooler already in place and I would be buying a a valvetrain kit along with the cam to make sure the engine can handle it...What would be the ideal size cam, and would you be able to here a lope at idle? I really like that sound, but I don't have the money to dump into heads and all that stuff, I am just a power hungry college student, so I want to make the most of my budget...Thanks
There's quite a few great cam-only cams out there. If you want help in that decision, check the drag racing forum below. It tells fastest cam-only times.
The cam-only locals are happiest with the G5X2, G5X3, and MS3. I watched a cam, header, cutout MS3 A4 put down 389hp on the dyno a couple of weeks ago. But I think your goals will determine your cam more than anything.
Do you want a top-end (high revs only) beast? Or do you prefer a wider, lower powerband?
Here I go whoring 4 texas speed click here This should be great, good with the stall and good DD cam just make sure you get a tune w/ your A4
It's what I have, stock heads/TB. And ur sig says u already have the LTs and exhaust to go w/ it. Go w/ it you'll love it. I have a m6 too, and it drives good, you'll definitely need a tune also.
Originally Posted by GreenBlood
safe to run without heads or ported throttle body for more air intake? (233/239)
There are people running the MS4 (239/242) on stock heads and intake.
im runing 23*/24* 60*/61* 113lsa on stock heads though a 3500 stall and 4.10s i saw allmost 400rwhp with a crapy tune ...for all of you who know jeremey formoto hes going to tune it and it should put down more...
ЯєŧąяĐ Єl¡m¡иąŧøя ™
