Turbo blazer has been dynod @ 8psi
Old 10-25-2006, 03:43 PM
02Vortech's Avatar
Default Turbo blazer has been dynod @ 8psi
GOT DYNO'D @ 8psi
Most runs where @ the 245whp mark and i had to @ 255whp- @ 8psi-10.5:1 a/f ratio
255.5 whp @ 10.5:1 a/f ratio
327 Ft.lbs @
MODIFCATIONS OTHER THEN THE TURBO AND TURBO TUNE-
msd coil-
NGK TR6 plugs-
March underdrive pullies-
thats it----
its a dynodynamics dyno- he said that it dyno's 5% lower then a dynojet so hopefully next time i dyno which will be on a dynojet i will make around 270whp @ 340ft.bls- but thats later- im definatly happy with the results-
it lights up the tires from a 20punch- thing is i have to hold it in gear for the 1/2 shift- because it dumps to much fuel through the **** and it boggs like a mother- so when i hold it and let it stop spining it hits the 2nd gear shift spins another 10ft and is off like a rocket- its hard to launch definatly-
dyno/burnout video and pictures will be up in about an hour
once i get ls1edit i think i could pull another 20 to 30whp out of it- cause thats on a base turbo tune- im trying to get it asap- the dyno guy said if i get ls1edit he will tune it for free- because im getting an older version that doesnt have a certain amount licenses- so i might up the boost to 11 and tune it- hopefully hit 330 to 340whp- ITS A MONSTER as is though
Old 10-25-2006, 03:51 PM
02Vortech's Avatar
Old 10-25-2006, 03:52 PM
trtturbo's Avatar
what do have as far as fuel? meth? etc..
Old 10-25-2006, 04:28 PM
02Vortech's Avatar
cartech fmu, procharger inline fuel pump--
that is with no tuning- hopefully with tuning i can pull another 20 to 30whp out of it-
stock motor other then the msd coil and pullies- its a monster to say the least
Old 10-25-2006, 07:58 PM
02Vortech's Avatar
video-
http://youtube.com/watch?v=oDDjDnDdhtk
Quick Reply: Turbo blazer has been dynod @ 8psi
