105-108 duty cycle??!!
I have a heads and cam 2001 camaro, with ls6 intake and all bolt ons, what would be the injectors that will fit my car needs, cuz the last time i was tuning it via hp tuner I saw that the duty cycle was at 105-108 % should i go with the 36 38 42.5 ?and what brand should I go with cuz the SVOs are a bit expensive and i found the Delphi brand on ebay for half the price. please help me i have no experience with injectors ,I’m going to swap the intake to 90/90 soon so please make a recommendation for the best injectors that i should go with.
Thanks in advance.
Thanks in advance.
Motrons, lucas, and seimans are good injector brands to go with. If your gong to use nitrous I would say fo with the 42LBs injectores. From your set up you have so far it looks like nitrous is the only thing left inless you plan on going FI anytime soon
Originally Posted by RedHardSupra
search for "bosch 42 injectors" on ebay, they have very good prices, flow matched, come with a flow sheet, i tested like 4 different sets on different setups, all work flawless, and they're much cheaper than most places.
