What carb hat are you using on your 4barrel TB?
Tin Foil Hat Wearin' Fool
Im thinkin of going with this one
http://www.superiorairflow.com/extreme_velocity.htm
I got a Edelbrock 4Barrel TB and a Vic Jr
would it really help a tb engine? it seems like that is designed to increase the signal at the venturis for better fuel atomization. a tb is already atomized right out of the injector, iirc. i'm no expert on fluid dynamics, so i'm curious as well, 1slow01z71. maybe someone that has experience with this piece will chime in. you should put a link to this in the sbc and bbc forum to gets more eyes on.
This is just what I found to turn my intake pipe down into my TB since it is mounted on the intake. I silicone coupler wont work and the rinky dink plastic **** I dont trust to 20#s of boost and nitrous going through it making it even more brital.
