Swapping heads only, need advice
The instruction on LS1howto is pretty good, but I need some advice anywhy.
1) I see no reason to remove the water pump, I'm not changing the cam. No bolts in the water pump go into the heads, only the block.
2) What is the best way to getting the steering pump out of the way?
a) do I remove the 3 bolts that hold the pump's mounting bracket to the head and lean the pump forward.
b) do I remove the pulley and then the two bolts that hold the pump to the mounting bracket. If I do this, how do I remove the pulley? what tool fits the center of the pulley, and is it simply turn off while holding the pulley?
I have a 1999 Camaro SS. I'm down to the water pump business for the dvr side head. The pass side head is ready to take off.
I can't remember the the pump having to come off if you're not doing a cam swap. So, I believe you're right there. Also, you can get the PS pump bracket off with a wrench and some patience. There is not need to have to pull the pulley off. The pump and bracket will come off in one piece. After it's off, just set it to the side.
Ben T.
Ben T.
You can probably do it this way, but I used the water pump holes and a miti-vac pump to suck the block dry and avoide a big mess when the heads come off. No coolant in bolt holes this way either.
I did it on a Vette and removed the bracket (PS pump and alternator bracket) and leaned it forward tying it with a small line to keep it out of the way. I have also read of a number of guys damaging the PS pulley when removing, so that might not be the best way to go unless you have to.
Is it a power steering pulley puller kit or a generic puller? I'm almost confident a conventional 3-jaw puller would crack the stock pulley to pieces. That's if you could get it to fit between the motor and the radiator.
Ben T.
Ben T.
orangeappeel: The instruction that I hardcopied are for "head swap". There is a separate set of instruction for "head and cam swap". The head swap only instruction do say to remove the water pump. I thnk that the head-cam swap instruction may have been written first, then they copied them to creat the head only swap but missed taking out the water pump pull stuff.
Anyway we all agree that the water pump does not get removed for swapping heads only.
Studytime: My pulley set has split jaws and an outer thin ring to keep them together. This worked very well.
To all: I am done,, I decided to pull the pulley, with the proper pulley puller set, the pulley came off rather easy.
Thankyou for all the help, you guys are great!!!!
There are a couple of threaded hex head plugs of the water jacket in the block. The easy one to remove is on the odd side. It nearly drains the block(big allen key). You should still use compressed air to get out any remaining water residue which won't be much after you pull the plug.
Ben T.
Ben T.
