FLEX PLATE INSTALL the spacer
I got the new tci flex plate do you have to put the washer space in the flex plate tried it and it puts my motor in a bind or do you use this spacer at all thanks
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by spy2520
i used the spacer and cracked my block and broke the pump in the trans, wasnt paying attention when putting the trans on i wouldnt make that mistake twice.
in fact, if you are using an ls1 converter, you will **** all your **** up once the bellhousing bolts start going in, ask me how i know...
hughes makes a spacer for the sbc converters to work with the ls1 http://store.summitracing.com/partde...5&autoview=sku
Originally Posted by blkbird_WS-6
IIRC, the spacer is for "old style" converters. They have a shorter "snout" on them compared to the LS1 converters, which have a longer "snout" therefore there is no need for the spacer if you have a verter for a LS1 application.
BTLFEDSS
