160 degree t-stat doesn't fit???
Old 10-27-2006, 02:36 AM
NAVYBLU-Z's Avatar
Default 160 degree t-stat doesn't fit???
Hey guys,
the other day I was attempting to swap in a Hypertech 160* t-stat (part # 1014) , and the it (portion that goes into the water pump) would not fit? Has anyone ever had this issue? This is my 3rd LS1, and on both of my '00's I had no problem. now I have a '02 B4C and I would've had to grind down atleast 1-2mm off each end to get it to work. No grinder, so I just ended up returning it. What gives?
Old 10-27-2006, 09:38 AM
2xLS1's Avatar
Someone has probably replaced the waterpump with the 04+ style. It is the only one available from GM now. You just need the new style t-stat. Check out Tbyrne (sponsor) for the best price on the new style one.
Old 10-27-2006, 01:49 PM
NAVYBLU-Z's Avatar
That would explain..Well, I'm glad CHP is on top of maintaining their vehicles!
Old 10-27-2006, 06:48 PM
NHRAFORMULA00's Avatar
We ran across this on my sons 2002 camaro,it had a newer water pump on it also(WE DID NOT KNOW AT FIRST) t-stat would not fit.Finaly found out the newer water pumps were a little different and took a larger t-stat,i think it was a lot cheaper too, like 20$
Old 10-27-2006, 08:28 PM
2001NBMZ28's Avatar
Yep, the water pump was replaced with the new PN. Think they came with a 185.
Old 10-27-2006, 08:42 PM
AppleMac's Avatar
Just double checking but you are putting it in right? not backwards?
Please do no take offense to this, just want to make sure...
It should go in like this:
Old 10-27-2006, 09:12 PM
2xLS1's Avatar
That is the new style t-stat for the 04+ WP. The older style t-stat is the housing and stat all one piece.
Old 10-28-2006, 02:08 AM
NAVYBLU-Z's Avatar
Yes, I was putting it in the right way, but the one I had also included the housing. i feel better now. Does anyone know where I can get the newer style t-stat? Someone mentioned a $20 one?
Old 10-30-2006, 07:14 PM
NAVYBLU-Z's Avatar
T T T
Old 10-30-2006, 07:52 PM
BayAreaSS's Avatar
Someone said to check Tbyrne. And where in the bay are you?
Old 11-01-2006, 10:50 AM
NAVYBLU-Z's Avatar
South San Francisco...
