rattling noises??
rattling noises??
i was just wondering if any of u guyz have what can be the cause of rattling noises that sounds like it might be coming from the rear hatch when going on bumpy roads...i hear it's common for f-bodies but there should be one way to stop it!! i completly stripped the hatch of the car and can't find any problems!!
rattle in rear area
Hey mine too 2002 Z28 Camaro I found the problem and I'm not to happy but all those Hole Shots took there toll!!!. My rear passanger axil is the noise. Not the bearing I replaced that, Its the carier inside the rearend the bushings on the spline end of the axil, and the splines and the Notch for the axil C clip are worn bad!!! The dealer shop manual under rearend noise tipped me off plus like you I checked my shocks and body pannels.
1 Post
Could be something more simple...Do you still have your spare tire, jack & ect still in the car? Sometimes those squeek alot if not secure.
Also, could be anything from your axle, rear-end, to your suspension...
