can a breather fit under a strut tower brace?
did the search and did not see a definite answer to the question. If it cannot is there another way to hook a breather up to help with crank case pressure other than putting one in the oil fill location?
they only fit with hotchkis stb i put a breather in the rear of my drivers side valve cover and i also switched to the ls6 style pcv system and im not pushing oil anymore on the 250 shot
well I will be putting one on my car with my strut bar if I can get the dam chimney off the car- the black plastic piece the holds the oil cap. If you take that off it will fit in there.
Originally Posted by 1999 SS
i have a BMR stb and am using a breather on the pass side. the back side of the breather will rest against the stb but it shouldnt be a problem.
