Sponsored by: DashLynx
Door refinishing help
Old 10-27-2006, 07:41 PM
Cephiros's Avatar
Default Door refinishing help
im repainting my door another color (well, a door to match MY car) first im curious the best way to go about it? theres chips in the paint is it best to put some filler int he chips then smooth it out/scruff up the paint and respray over it, or is it recommended to sand the paint completly off to primer and do the whole thing? or is there a better method than sanding?
second question is how do i get the squeegee off the door so i can clean/respray under it so you dont see the blue at the bottom when you look close.
Old 10-28-2006, 10:46 AM
Cephiros's Avatar
bump for the day
nobody knows?
Old 10-28-2006, 11:02 AM
ls1transam346's Avatar
best way to do it is to sand it down till you cant feel the chips anymore. make sure the sanding is not done in just those small areas but a good radius around it so you cant see or feel like a dip. it wouldnt hurt to spray primer on those areas. sand the whole door with like 800. get it nice and smooth then spray. for the squeegee they should just pull out. should be able to reuse them but if not they are cheap.
Old 10-28-2006, 11:15 AM
Cephiros's Avatar
thank you
yeah i got a reply about the squeegee on another board froma freind was still looking for advice on the paint, thank
Old 10-28-2006, 03:04 PM
Cephiros's Avatar
should have asked when i first posted but didnt think of it, but is there any special type of primer i should be using on these doors or will any old primer do?
Quick Reply: Door refinishing help
