Block off plates?
Block off plates?
ok, so a friend who is going to help me put my headers on told me to get some block off plates for my headers. Other than less **** to mess with when u do this, whats the advantage of using the plates. Oh, and yes i do know what they are.
The advantage is less clutter in the engine bay , no EGR / AIR .
Find out how strict your states emissions testing is before hand .
Where I live we run dominator carbs on the street and open headers ,no emissions testing.
So you can delete the AIR system and associated hoses/pipes, no EGR on yours if they're 01/02 headers right?
Location: Your girl's back door giving her the long stroke while you're at work
Yes depending on how strict your local testing is you can remove the A.I.R. junk. If you need to make block-off plates then get some thin sheet metal and trace the factory A.I.R. fitting and cut it out with tin snips
well hoss,i ordered them with emmisions provisions cause 1, im new at these kind of mods and 2, i dont want to fail inspections!!!! The friend who is going to help me put them on said in va, i wont have to worry about it! I would rather have them and just block off the air then be able to take off the plates if it causes problems later on down the road for inspections!!!!!!
everything is done as far as what? U still need to do the big part as far as drop in the damn tranny!!!!!!! So is this all going on at the hobby shop? Got any help? Did u sell the T56?
