Help me find a cam for AFR heads?? Or do you suggest other heads??
I want the most aggressive setup I can run on a stock bottom end! I plan on spraying this setup with 150 to 200hp shot of spray.
I don't care about the drivabililty TOO much but would like to be able to drive the car to work on a special day every now and again.
I basically want as much power as I can out of a top notch heads and cam combo!!
Any suggestions? Could you give some info on your choices?
Take a look at this one :
https://ls1tech.com/forums/lsx-parts-sale/598965-228-230-0-639-0-592-112lsa-112icl-lsk-xer-lobes.html
Christian
Christian
LGM G5X3, AFR 205, .040 Cometics, flycut pistons = 480+ rwhp with supporting mods and attention to built details (cam degreing, lots of dyno tune time, 90/90 {ported} etc...)
