Trent
10-28-2006, 01:29 PM
In the past two days, I have pretty much replaced everything in the clutch system. I replaced the master, the slave, the clutch w/ a stock Z06 setup including flywheel, new pilot bearing, new throwout bearing, etc etc etc...
Tranny has been filled w/ Mobil 1 ATF fluid and when the car is off will shift in and out of gear fine. Clutch feels fine after bleeding as well. However, it will not shift into gear smoothly. Its a pretty good effort to shift it.
I have tried the Mighty Vac method, the GM TSB bleeding method, the old fashioned slave bleeding under the car method, and nothing fixes this. I have replaced everything and it still won't shift smoothly.
Am I missing something?
