Can a bent frame be fixed and hold up to 1000 rwhp with 25.2 cage????
Old 10-28-2006, 02:33 PM
ebaker's Avatar
Default Can a bent frame be fixed and hold up to 1000 rwhp with 25.2 cage????
I am looking into buying a 98 wrecked ta roller for 750, and the guy told me it has a little bend in the frame that he said could be fixed, and if i put a 25.2 cage on it i wouldnt even have to worry about the frame being bent. Is this true??? Or should i just look for another car???? please guys i need your help. thanks in advance.
ebaker is offline
Old 10-28-2006, 07:13 PM
Formula350's Avatar
Depending where the bend is, you could always find another junker with that part of the frame good, and cut-n-weld it in. I'd probably, just to be sure, put on some subframe connectors heh. The rollcage WILL help tons. I assume 25.2 goes to the rear and the front under the hood?
Formula350 is offline
Old 10-28-2006, 10:51 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I thought you already bought it?
Originally Posted by ebaker
ok guys its too late i just made the deal today!!!! sorry
https://ls1tech.com/forums/pontiac-firebird-1967-2002/597126-wrecked-98-trans-am-750-worth.html
y2k_ta is offline
Quick Reply: Can a bent frame be fixed and hold up to 1000 rwhp with 25.2 cage????
