Installed Yank have questions (slipping)
I just finished putting my Yank SS3200 in the vette. How long should it take for the tranny to stop slipping? Another words how long should it take for the fluid to circulate through the converter and tranny lines. My tranny is slipping bad after it runs for a minute or two. If I kill it then restart it's fine for a couple of minutes then it starts slipping. Yes I did fill the converter with fluid before I installed it (1 quart). I didn't fill the tranny because I didn't lose much fluid when installing it. Pretty sure it's low on fluid, that's how it's acting. Thanks in advance.
Originally Posted by Blacker
Check the fluid level and check it when it is hot. The TC will slip since that is the purpose of it. A tune will not help in this instance.
Car's already tuned. That's the answer I was looking for. I wasn't sure how much fluid the converter held.
Definatley not confusing the stall for slip. I took out a 4K stall for a 3200.
I'll add some fluid tomorrow.
