TC operational info
TC operational info
I understand a higher stall TC increase your off the line performance, but i'm confused as to what the TC actually does in the drive train. Can someone explain it to me? I'm a mechanical engineer so you don't have to put it in lamen terms. lol
-Jason
-Jason
Originally Posted by BlackHawk T/A
No, the stall speed is affected by how the torque converter is made (angle of the fins and such)
The clutch just locks the unit so you stop slipping (much like a manual transmission). This isn't done until higher speeds.
There is Flash Stall, which is the RPM your converter will jump to when the car goes WOT from idle. At this RPM it will send the power down the line, so to speak.
Brake stall is how high it will spin to before trying to move the car, while the brakes are applied.
The stall ratings you see are flash stall.
