cam installed and tune, do i need to drill the TB? Video
Here is the video of it idling after the tune. It still doesn't idle very well when I first start it. Since I had the tune done would I maybe still need to drill the TB? It seems to be fine for the most part when it's warmed up. Or is this normal for a cam? VIDEO
Originally Posted by yak
that's actually not bad at all imo. it hunts for idel for a few seconds. DO NOT drill your tb, ever! take your tb off and open the set screw 1/2 turn. then reset the tps. that should help.
Drilling a hole in the TB is a stopgap. A good tune should not require this. I don't have any holes in mine and it starts and runs like a top. Hot or cold it starts and purrs.
