New Coil Relocation Kit - take a look
Old 10-29-2006, 08:15 PM
C_Williams's Avatar
Default New Coil Relocation Kit - take a look
Totally adjustable - rotation, spacing, height and should work with any cover combination...
Tall Covers
Medium Height Covers - rotated coils
Medium Height Covers - straight coils
Old 10-29-2006, 08:36 PM
99sprayjunkie's Avatar
Sweet.
Im diggin the angled setup, real nice.
Are these available, or a one off design?
How much $$$ ???
Old 10-29-2006, 09:24 PM
~JOSHUA's Avatar
don't even think about responding with a price...
Very nice set-up by the way.
Old 10-29-2006, 09:41 PM
AppleMac's Avatar
JMO...
But I think the point of relocation coil packs is to completely remove them from the area around the valve covers... With this you still have wires going over the valve covers and still looks kinda crowded... I like the "under the cowl look."
Still looks way better than stock
Old 10-29-2006, 09:52 PM
Cop Car's Avatar
the point of coil relocators is when you change to other valve covers that dont have coil mounting points. there is actualy a performance reason, not a looks reason.
only reason why id ever think about moving the coils were if i had to get a diffrent set of valve covers to clear rockers
Old 10-29-2006, 09:53 PM
TECH Cry Baby BOSS APPROVED!
Urban Legend's Avatar
Looks good.
Old 10-29-2006, 11:41 PM
Restricted User
Smokin87TA's Avatar
Very nice looking, especially the angled look.
Old 10-30-2006, 09:06 AM
02NBMFormula's Avatar
looks nice. how expensive are they???
Old 10-30-2006, 09:16 AM
AppleMac's Avatar
You must mean performance for the worse... Longer plug wires = more resistance = Less power...
If it is pure performance anyone can weld mounting bungs on their valve covers and have shorter wires. (Most aftermarket tall valve covers come with this option from the shop.) Not to mention it is probably far cheaper to do it this way.
You have an appearance mod... Which is cool.
I am relocating my coil packs to a place where they will look better
Old 10-30-2006, 09:34 AM
NOBR8KSS's Avatar
I think he means performance from a functionality standpoint....as in they perform their intended function.
Old 10-31-2006, 07:45 PM
Brian2001SS's Avatar
Where can I get a set of those Corvette valve covers? They would really look great if they were engraved with CAMARO SS.
By the way, the relocation method looks like a winner.
Old 11-01-2006, 02:11 AM
ultraz's Avatar
Longer wires can easily be compensated by using more strands of wire, thicker wire, material used. I dont think it would do much to hurt performance adding 1 inch of wire to a set of plugs. these relocation kits seem to usually decrease the size.
Old 11-07-2006, 08:01 PM
WILWAXU's Avatar
Those are C5R valve covers. I think Katech can hook you up with a set
