longer crank bolt
Old 10-30-2006, 09:38 AM
xtinctbird's Avatar
Default longer crank bolt
Anyone know where I can get a longer crank bolt to use to get the crank pully back on? I've tried autozone, napa, advanced, ace hardware and napa with no luck
Old 10-30-2006, 09:41 AM
Slow00ls1T/a's Avatar
i got mine from ace hardware
Old 10-30-2006, 09:45 AM
xtinctbird's Avatar
do you know what the specs on it were?
Old 10-30-2006, 09:54 AM
Jroc99SS's Avatar
m16 x 2.0 pitch x 120mm long
Old 10-30-2006, 01:20 PM
Fratsit's Avatar
I bought mine from a nut and bolt store.
R/
Frat
Old 10-30-2006, 01:37 PM
Camaroholic's Avatar
If you go to a local industrial bolt store you can get a piece of threaded rod and nuts. 3 feet of threaded rod, 4 nuts, and 2 washers cost me under $20. Spent a little time with a hacksaw, and now I have an installation tool, a piece that I use to push against, and enough left over to build another one.
You really don't want to "pull" the balancer on with a bolt. You really should "push" it on with a nut and piece of threaded rod. $20 for the tools to do it right is much cheaper than extracting a broken bolt and then getting your crank snout helicoiled.
Old 10-30-2006, 01:50 PM
BriGuy's Avatar
I agree with Camaroholic. Especially when people have broken the bolt off inside trying to pull it on like that. I broke one myself too. Now I have a piece of threaded rod that I use to pull it on. Granted I had done at least 10-11 cam swaps before I had one break. But just one break was enough for me not to trust that method anymore.
Old 10-30-2006, 04:36 PM
Big Budda's Avatar
www.mcmaster-carr.com
go with the threaded rod for sure
Old 10-30-2006, 06:00 PM
Moderator
davered00ss's Avatar
Check out the tools section. There is amamber selling a tool he made. Looks like it's worth it to get one.
Old 10-30-2006, 06:36 PM
Oh4GTO's Avatar
The ARP crank bolts are longer. Anyone know if they are long enough to get the pulley on?
Old 10-30-2006, 10:07 PM
11Second Club
Gauge's Avatar
618HAWK sells a tool that works quite well. I bought one from him, and I love it. I'm sure you could make one yourself, but he ships promptly, already has the stuff, and probably doesn't charge a whole lot more than it costs to make. Just send him a PM if you're interested.
Here are some pictures of the tool...
Old 10-30-2006, 11:27 PM
Blown_Red_97z's Avatar
I second the whole "do not pull the balancer back on". Even though it was an LT1, I stripped the threads inside the crankshaft trying to do this, ended up having to retap the threads and using the push method instead. Avoid the hassle.
Old 10-30-2006, 11:33 PM
Long Beach's Avatar
I would also like to know if the arp bolt is longer and will work?
Old 10-31-2006, 01:56 PM
stealth71's Avatar
I second 618Hawk's tool. I just got one from him a couple weeks ago. It is worth the $$ and he shipped it really fast.
Old 10-31-2006, 04:54 PM
BriancWS6's Avatar
I'm sure that the tool or long threaded rod works well, but in my case I needed to get the car back together ASAP so I made a longer bolt
Old 10-31-2006, 07:58 PM
BudH's Avatar
NAPA in Memphis had them in stock!
Old 10-31-2006, 08:04 PM
wht01ws6ta's Avatar
I looked at about 10 different places for a longer bolt but couldn't find one anywhere. However, I did find a 1 meter piece of 16mm 2.0 pitch threaded rod and a couple of nuts and washers to match which worked very well to push the pulley back on. A local nut and bolt warehouse had the stuff.
Old 11-01-2006, 04:34 PM
Oh4GTO's Avatar
TTT for the ARP bolt question.
Old 11-01-2006, 08:49 PM
Long Beach's Avatar
Thats the awnser im waiting for
Old 11-03-2006, 04:23 PM
Oh4GTO's Avatar
TTT again.
