obtaining 11s........
With my current mods I think my car is capable of 12s. I was wondering what some of your thoughts were towards having an 11 second N/A daily driver car. Would it be possible?
My current mods are listed in my sig. I wanted to keep the stock heads, and I'm hoping with an upgraded valvetrain, gears, and of course drag radials I'll be close to 11s. I drive my car just about everyday and I don't want to sacrifice reliability, so does this sound realistic?
I did some research on cams, and I was leaning towards the TSP Torquer v.2, but I wasn't sure if that would be too big a cam for daily driving. I also was checking out some Comp Cams and found the 275Xtreme RPM seemed to work well. I know cam selection is very complicated and can be a long process, so I definetely don't want to throw in a huge cam just because it sounds choppy at idle.
If anybody out there has an 11 second daily driver, let me know how you like your cam. Thanks a lot!!
Originally Posted by bjamick
have you had your car dynoed?? we have bout the same mods exactly LOL
Originally Posted by nseldy
Doesn't anybody out there have 11 second N/A daily driver F-bodies?
Originally Posted by staringback05
moderate heads and cam, but a good tune also...youll get in the mid to high 11s
Originally Posted by mattraypharbor
I do...its great cam only set up...7.7s in the 1/8th high 11s in the 1/4 with two jl twelves in a heavy *** box...1.6 60's full weight with spare...
Thanks!
You really only need 3 big mods for an M6. 12 bolt rear end, a stout clutch, and a serious driveshaft. Drop some weight, do the standard lid/headers/exhaust, and you'll be very close. A cam will put you over the top (my car went 11.85 with a B1 cam - 221/221 .556/.556 114LSA). The way to get it is to drive it like you stole it. Seriously. On a stock motor, bounce that sucker off the rev limiter to launch it (assuming sticky tires). That's why you need the 12-bolt and clutch/driveshaft. Don't fear the gear. 4.30's or 4.56's are GREAT in a 6 speed.
Walk down the dark path... 4.56's are very, very fun.
All you need is a Ls6 manifold, Ford 9" ( preferrable 4.11s) and Slicks. WIth all those you should be able to be 11.99s! without gears you may be 12 flats. But the tires are a must for a quick time. But you need a rearend also if you are gonna launch that high. So with slicks and a rearend and gears you should be able to accomplish 12 flats, thats why I said 11.99.
because without the rearend, or slicks, or the shifter and on a stock fried clutch and I dont have the bigger MAF, but I have an LS6 intake manifold. and LT and ORY with LM. I run 8.07 in the 1/8 and that is 12.5s in the 1/4 with a 1.89 60'
thats why with slicks if you can cut your 60 to a 1.7 you should be able to be right on the dot of 12. and if you powershift. 11.99 is accomplishable.
That's pretty good for a cam only car! So how do you like the cam for daily driving? What cam is it, and do you have the specs if you don't mind me asking?
Thanks!
Thanks!
I went 7.5's today cam only muaahahhaha anyway ya i'll send ya the specs
OK, Thanks for the help....... Now for a decent street cam, How about the TSP torquer V2, is it too big for daily driving? I also plan on changing valve springs, pushrods, rockers at the same time.
I want to make sure the car stays reliable, but I also want as much peformance as possible. I guess it's hard to have both!!
Thanks Again
Thanks Again
my car so far has always been reiliable even after all the **** i did to it..
