Need Help With Hissing Noise Under My Hood!!
Old 10-31-2006, 07:51 PM
02BlackMachine's Avatar
Default Need Help With Hissing Noise Under My Hood!!
When I Drive My Car Around Sometimes I Hear A Hissing...more Like Pressure Coming From My Engine Bay Area , Around The Driver Side..ive Stopped To Check When I Hear It And It Goes Away, I Only Hear It Sometimes When Im Driving Around 15-30 Mph. Could It Be My Air Intake Or Something Else?
Old 10-31-2006, 08:12 PM
TORCHD 02 TA's Avatar
it is called you A.I.R Pump. you can get rid of it. but will need to hp tuners to tune it out
Old 10-31-2006, 10:12 PM
Danny2tek's Avatar
yep sounds like the air pump
Old 10-31-2006, 11:02 PM
staringback05's Avatar
does it go away because of the mph or does it go away after a certain amount of time?.....after an amount of time...air pump....just after mph....exhaust leak
Old 10-31-2006, 11:41 PM
thanx alot for yall help, i'll jack my car up and look at the exhaust... and maybe work at getting a new air pump
Old 10-31-2006, 11:49 PM
i wouldnt mess with the air pump...broke or not...if you plan on doing any aftermarket exhaust....if not, then find a used one...alot of people are getting rid of them
Old 11-01-2006, 12:51 AM
I Already Have An Slp Loudmouth Exhaust.... Should I Remove It?
