LT1 355 refresh...Specs inside...What would you do?
Got my engine out out and I am feeling the waters for a 355 refresh. The cylinders look by and large good with some minor wear. Maybe I don't even need boring, honing may do the trick.
I am more interested in honing or 355 rather than 383, I don't have the money for a full blown 383 plus I still need decent MPG. My goal is around 400 RWHP and reving to 6400 RPM.
Here are my future specs:
LE2 heads
LE 1.5 cam
Impala head gaskets
LE ported intake
Rest of specs in signature
I am willing to trade some HP for longevity, I want a setup that will last and last plus I will never have juice or power adder. Please post suggestions on individual components or full rotating assemblies.
LE2 heads
LE 1.5 cam
Impala head gaskets
LE ported intake
Why Not? If the block is decked you could run into valve to piston clearance. I went with the Impala gaskets .029 vs the felpro's at .026 for that reason. At TDC the pistons were .008 in the hole. My compression may have dropped a couple of points but I would rather have a little less compression than worry about clearance. Just my opinion.
HVY SS
HVY SS
