Broken rockers or springs??
Old 10-31-2006, 10:20 PM
SPRAYED 01's Avatar
Default Broken rockers or springs??
Any one ever crack or destroy a stock rocker arm? Trying to diagnose a bad back fire type popping noise and lack of alot of power. Also has any one ever cracked a crane dual spring? I get no codes its intermitant.
Old 10-31-2006, 10:23 PM
camarochvy21's Avatar
I have seen people brake dual springs before. Pull you vavle covers and check
Old 11-01-2006, 05:11 AM
vettenuts's Avatar
If you are pushing the springs to coil bind, you will likely break the rocker. There have been some failures of the Crane 832's but initial setup usually is a player in these failures.
