What Cam?
What Cam?
I have a 66 elcomino. i am dropping a crate ls1 in it and a t 56. I plan on going with 3.50's in the rear end. The car is going to be a daily driver. The cam oviously cant be big but if someone can recomend something i would realy apreciate it. Thanks.
i went with the ls6 cam and thats very mild. its 550 lift with 218 / 204 duration. no lope sound, you can't even tell theres a cam (don't forget better valve springs if your above 525 lift!). i'm conservative. i wish i would have chosen lunatis cam 558 lift, 221/ 221 duration. still not radical. also i have a A4 . this cam should make good power up to 6000 rpm . i'm not a high winder, i use to own pontiac, 5000 was danger! good luck with your selection.
