Gears & Axles - 5/8 studs
View Full Version : 5/8 studs
1redta
11-01-2006, 09:52 PM
the rear end I currently have on my car (Moser 35 spline gun drilled star cut)has the moroso 5/8 studs, they are great for draglite type rims but stock type wheels you need acorn type lug nuts to locate the rims, is there a way I can switch them out to the regular 1/2 studs from 5/8? I don't want to have to buy new axles to mount up some regular rims that use the acorn type of lug nut Thanks Art
Firechikn
11-02-2006, 06:30 AM
Take the axles to a machine shop and let them redrill new holes in the flange.
8a8mfh
11-02-2006, 05:17 PM
Only problem is that they are star cut. They 5/8 holes need to be welded shut and redrilled. Thats going to run the price up if that can even be done.
1redta
11-03-2006, 09:21 AM
damn street stars it is thanks guys
SPEEDYws6
11-03-2006, 10:47 AM
I was in a bind once and had to put a set of stock wheels on my 5/8 studs, so I bought a set of 5/8 acorn style lugs out of the circle track section in jegs.
1redta
11-04-2006, 09:13 AM
didn't even think about circle track studs good idea
