royal purple or mobile one
Old 11-01-2006, 11:32 PM
famousracer21's Avatar
Default royal purple or mobile one
which oil is better for a 2000 camaro ss. fully synthetic mobil one or royal purple.? If i put an ls6 intake on my ss what other things would i have to change and how much horse power will i gain.
Old 11-02-2006, 12:12 PM
Lucas'02SS's Avatar
Well most people will tell you that you will get better power from running Royal Purple, but you have to run all Royal Purple products such as the tranny oil to get the benefits of it, not just the RP motor oil. But you will pay for it, cuz it's more expensive than Mobil1. I run Mobil1 in my car, and I make really good power for a stock car. It's kinda your preference. If you switch to all RP you will prob gain a few HP
Old 11-02-2006, 01:15 PM
PowerShift408's Avatar
I really don't think you're gong to gain any power whatsoever from an oil change.
Old 11-02-2006, 01:37 PM
BayAreaSS's Avatar
I use mobil 1
Old 11-02-2006, 02:24 PM
SSmokin99's Avatar
I use 0w30. The one that's made in Germany.
Old 11-02-2006, 02:34 PM
Lucas'02SS's Avatar
You won't from just an oil change, but if you switch all of your fluids to Royal Purple you will gain some HP. Its been done, and I talked to a GM technician who said it worked.
Old 11-02-2006, 02:36 PM
Lucas'02SS's Avatar
There are different 0W-30's. You're talking about German Castrol, but Mobil1 also makes it and a couple other brands here in America.
Old 11-02-2006, 04:42 PM
GoldenBird's Avatar
+1 for the German Castrol....do a search on it, plenty of info here and I'm far from the only person who will tell you it's the best oil money can buy for our cars. It's truly the fountain of youth for the LS1.
Old 11-02-2006, 05:47 PM
SSmokin99's Avatar
Yes, the German Castrol one.
Old 11-02-2006, 08:10 PM
'Trust''s Avatar
RP would be the better choice, but it is expensive. Horse Power TV or someone did a test with RP differential fluid and traanny fluid and claimed to gain 8 HP, although 5 of that could have been from simply a different pull, maybe 3 from clearing out the gunk of an old rear and tranny, its definately debatable. But as far as engine oil, I use Mobil 1 5w30, alot of people run 0w30 GC, however the shop down here (which has built a 9 sec 3800lbs TA with a 4L60E, a 10.16 @ 142 FRC with street tires, a 10.32 HOSS with a mild H/C combo and spray, all full weight and many others, and also are ASE Master Techs) did mention that they have torn down tons of motors with Mobil 1 and even the ones with 100k+ look new inside. Judge for yourself, I'm not saying RP is worse, its not, but Mobil 1 isn't crap either.
Old 11-02-2006, 08:16 PM
ULTIMATEORANGESS's Avatar
i just put RP motor oil in my SS last weekend. it was the same cost as M1 so i decided to go with it. ive heard good things about both.
Old 11-02-2006, 08:18 PM
'Trust''s Avatar
ULTIMATEORANGESS where did you get it at the same price? I'd like to try it if its close!
Old 11-02-2006, 09:04 PM
i got it at pep boys. they were next to each other on the shelf. i was surprised. 6 QTs and a filter only cost $57.
Old 11-02-2006, 09:07 PM
spare tire's Avatar
Mobile 1 0-40 all the way, Had RP 5-30. Car had 30psi of oil press. at idle. Switched to the M1 0-40 now the oil press. is at 40 at idle engine seems to run quieter as well.
