Can I make 400hp with 228R??
Old 11-01-2006, 11:57 PM
BayAreaSS's Avatar
Default Can I make 400hp with 228R??
Do you guys think i can get 400hp with the 228R cam from TSP?
The supporting mods will be.....LT's/ORY thru a cutout in the I-pipe, LS6 intake mani, lid,filter,bellow,MAF,CAI, P&P TB.
So what do you guys think?
Thanks for you input
Old 11-02-2006, 12:07 AM
texasheat's Avatar
Yes! Check my sig...
Old 11-02-2006, 12:08 AM
staringback05's Avatar
with a good tune, yes i could see possible...for sure with a good set of heads...
Old 11-02-2006, 12:12 AM
BayAreaSS's Avatar
Thanks for the quick replies. Texasheat your numbers are right on the money
Old 11-02-2006, 12:23 AM
Iron Sights's Avatar
Nice numbers, especially since it looks like you're without an U/D pulley.
Old 11-02-2006, 07:21 AM
slow trap's Avatar
i was only in the 38x range but i'm sure with a ud pulley and great tune 39x was possible.the 228 is a great all around cam that peaks fairly early so you don't have to wind it to the moon .
Old 11-02-2006, 07:28 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
I bet you can. Don't see what not.
Old 11-02-2006, 01:45 PM
BayAreaSS's Avatar
Where did you redline?
Old 11-02-2006, 01:47 PM
TXZ28LS1's Avatar
im pretty sure you will be close. $hit, thunder racing didi 390ish with a 224 cam. so i can see it doable.
Old 11-02-2006, 02:00 PM
BayAreaSS's Avatar
I think it will be close. I guess if i make 390 i could get a UD pulley or EWP to try and reach 400. But i hope the 228 can make 400. But i guess it really doesnt matter because its just numbers. Either way the car is gonna haul ***!
Old 11-02-2006, 02:05 PM
you2slo's Avatar
With mine, I put down the #'s in sig. They aren't that high but the car runs 11's.
Old 11-02-2006, 02:53 PM
Ryan02SS's Avatar
I hit 399rwhp with my TR224 back in 03 with every bolt on save an EWP. Tune was razor sharp thru ORY and open QTEC. I don't see why not.
Old 11-02-2006, 04:50 PM
slow trap's Avatar
i think it was between 6150-6200 is where it peaked. mine was on a 112 +2.
Old 11-02-2006, 06:36 PM
Phil'sC5vette's Avatar
I have the TSP228R. I havent dyno'd it, but this is what I figured.
I had all the bolt ons and a TR224 cam, and it dymo'd at 370RWHP. The 228R is good for maybe 8-10 RWHP more according to TSP. So lets say now im at 380RWHP and Ive added AFR heads milled .20 off which I figure are good for 40 RWHP. So I figure I have 420 RWHP, but my tune is not razor sharp and the tuner thinks it's a bad cam to tune. This is his quote:
"As I have stated in past posts I am not a fan of more duration on the intake and same spec cams intake/exhaust. Its been proven time and time again you need to run mininum of 4 degrees more on the exhaust to get the combo to sing. I've advised many people not to use certain cams and they end up unhappy".
The car bucks at low RPMs in any gear, but it's most evident in 1st car between 1500 and 1900 RPMs
Old 11-02-2006, 07:31 PM
jay_99z's Avatar
What kind of numbers did you put down stock?
Old 11-02-2006, 08:27 PM
02 Camaro SS's Avatar
I made 419rwhp/386rwtq on the stock rear/3.42s with slp longtubes/ory with a comp 228/222 114lsa.
Old 11-02-2006, 08:32 PM
DONAIMIAN's Avatar
I made 400 with a 221/221 cam, but I also have every possible bolt on.
Old 11-02-2006, 08:37 PM
bad6as's Avatar
if a 228/228r whats it a xer on .588 can make 400hp then the cam i want 227/231 .636 .639 on 110 should be able to make over 400 cam only
Old 11-02-2006, 11:48 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Does that include a EWP?
Old 11-03-2006, 12:20 AM
texasheat's Avatar
313rwhp/327rwtq stock
bolt-ons and tune 357rwhp 363rwtq
Quick Reply: Can I make 400hp with 228R??
