General Maintenance & Repairs - New front brake pads are squeaking, mechanic says wait a few hundred miles
I just got new pads put on the front of my car about 2 weeks or so ago. The brakes had started to squeak before that so I took it in and they told me I needed new pads. Once they were replaced they were quiet for a few days but then the new ones started squeaking even more often than the old ones.
I took it back to the mechanic today and they said they cleaned everything up but the brakes are still squeaking. They also said to wait about 400-500 miles before I bring it back because usually noise will go away with time on new pads. They said if the brakes still squeak after that they will start to try different pads and such.
So is this "wait and see if the new pads stop squeaking" accurate? Or am I wasting my time? It's just extremely annoying. I also read on some site earlier that a guy's mechanic told him to find an open road with no traffic, go 50mph and then do a hard stop. He said to do this 5 times and that would help. Should I try that too?
Asmodeus
11-02-2006, 03:51 PM
yeah, they're right. The open road thing might help too. They probably got some grease on the pad surface.. takes a little while for it to wear off.
wht01ws6ta
11-02-2006, 03:59 PM
When I had the same problem I took them back off and just cleaned the rotors and pads w/ brake cleaner and that solved it but the trouble might not be worth it to you if they will just fix themselves eventually
SoCalZ28
11-02-2006, 06:30 PM
Sounds like maybe the pads need to be bedded with the rotors. Here is a link to Wilwood page that tells the recomended procedure http://brakepads.wilwood.com/03-tech/index.html
Pewterpower
11-02-2006, 07:25 PM
I just did pads and rotors myself and they were smoking, stinking, squealing, vibrating....
After a few hundred miles though, and some hard stops, they were smooth as a baby's ass.
massls1guy
11-02-2006, 11:50 PM
Not an expert here... but I think some squeak can come from the pad vibrating between the piston and disc. I used the pink goop (comes in blue flavor too) on the back of my Hawk HPS pads. It's supposed to be a buffer to prevent vibration. My setup is quiet so far. Cheap stuff, give it a shot.
Thanks for the replies. I'm going to try the bedding technique linked above when I get some time tomorrow afternoon.
wade99z
11-03-2006, 02:41 PM
Bedding pads requires short casual stops first, building up to higher speeds. If you go out and try to bed them from highway speed stops first, you'll probably just glaze them over, which will cause them to squeal.
In my experience, a pad that sqeals from the beginning will continue to do so, all else being correct. In that regard, clean the rotor and pad with brake cleaner, scuff the surfaces with course sandpaper, and then try the goo on all mating surfaces between the pad and caliper as mentioned above. The stuff I use is orange. Should be able to get it at autozone, pep boys, etc ... That's usually the culprit if not the pad itself. Cheaper pads with a high metal content tend to squeal the worst.
The worst set of pads I ever had was a set a brake shop put on my '91 Corvette (apartment dweller at the time). Sounded like a bus coming to a stop for the month or so I ran them. After several back and forths to the shop, I ended up just redoing it myself one weekend when I was at home with a better quality set of pads, that actually cost less than the "premium" set the brake shop put on. Lesson learned.
98boxer
11-04-2006, 12:06 PM
What i did with mine is i made a few hard stops and a few burn outs with the brakes applied and the squeking went away, but only after 100 miles were put on the car, after i installed my brakes, which was recommended i think by instructions or hayes manual.
