Nitro Dave's Nitrous Outlet
11-02-2006, 04:46 PM
Thats right its FREE month here at Nitrous Outlet... In case you missed it I said FREE FREE FREE FREE FREE FREE !!!!!!!!!!!!!!
Group1
This one is perfect for you Corvette guys.
Our dual nozzle dry system.
This system comes with a 10lb bottle, high flow valve(side port design), 20 foot main feed line, stainless steel bottle brackets, 500 hp solenoids, 2 foot -3 hose/90 degree ends, jetting for 70-100-150, all fittings, hoses, fuel pressure safety switch, nitrous pressure gauge, nhra blow off valve, and blow down tube.
With this system you get a FREE Nitrous Outlet Purge kit. :)
http://www.nitrousoutlet.com/catalog/product_details.asp?group=23&model=80&dept=11&product_id=2184
COST
499.99
Group 2
Single nozzle dry system.
This system comes with a 10lb bottle, high flow valve(side port design), 20 foot main feed line, stainless steel bottle brackets, 150hp solenoid, Jetting from 50-100-150, and all Hoses fittings etc.
With this system you get a FREE switch panel. :)
http://www.nitrousoutlet.com/catalog/models.asp?group=26&model=82&dept=11
You can choose from either of the F-body ashtray panels, GTO fold up, GTO slide in, or either one of our truck panels.
Cost
340.00
Group 3
WET/ DRY Dual stage combo..
This system comes with your choice of a stock or 90 mm plate, 10lb bottle, high flow valve(side port design), 16 foot main feed line, solenoids, jetting from 50-150, all hoses and fittings. The Dry side will consist of a 150 hp solenoid, single dry nozzle, jets from 50-100-150, all needed fittings and hoses.
With this system you get a FREE dual stage window switch. :)
http://www.nitrousoutlet.com/catalog/product_details.asp?group=26&model=86&dept=11&product_id=964
Cost 825.00 (97-04 vette add 25.00 or GM Truck add 30.00.)
Group 4
Plate system.
Your choice of the stock or 90mm plate system,10lb bottle, high flow valve(side port design), 16 foot main feed line, solenoids, jetting from 50-150, all hoses and fittings.
With this system you will get a FREE Switch panel. :)
Cost 650.00 (97-04 vette add 25.00 or GM Truck add 30.00.)
Group 5
NX single nozzle system. Part number 20920-10
http://www.nitrousoutlet.com/catalog/product_details.asp?group=14&model=37&dept=11&product_id=68
Cost 609.00
!!!!!!!READ THIS!!!!!!!
1. Now here is the sweet part for everyone. With any purchase over 50.00 you will recieve a FREE NX octane booster with your order.(while supplies last) :)
2. With any purchase placed in the month of November you will be entered in a drawing for a FREE custom painted Nitrous bottle. You will need to tell us what site you read this on!!! :)
http://img55.imageshack.us/img55/6509/ltngbottlecust1ku0.jpg (http://imageshack.us)
You can call in your order at 1-866-648-7637.
This special is good until the end of November...
Thanks
Dave
Group1
COST
499.99
Group 2
Cost
340.00
Group 3
Group 4
Plate system.
Group 5
Cost 609.00
Thanks
Dave
