QTP vs. KOOKS
Old 11-03-2006, 01:01 AM
00Formula00's Avatar
Default QTP vs. KOOKS
Just trying to decide between these two bastards...
Seems like everyone has problems with installing QTP
How did the KOOKS go? Installation problems?
Old 11-03-2006, 02:53 AM
BirdmanLS1's Avatar
Ok the problem with installing QTP's was along time ago with a bad batch (i was unfortunate and got that bad batch), I am pretty sure they have corrected those problems, (correct me if Im wrong). As far as performance goes, QTPs are nice. I make about 334 hp, 345 tq with just the lt's, CAI and leaks in my exhaust untuned and with my cutouts closed. With a tune and my tru duals i should be makin close to 350 hp with just full exhaust and a tune... so that gives u a good idea of QTP's performance.
Kooks are equally good from what ive heard so u cant go wrong with either. Maybe it should come down to pricing.
Old 11-03-2006, 08:43 AM
02SS0384's Avatar
My Kooks went in extreamly easy, I just had to remove the dip stick to get to a manfold bolt nothing else and no grinding. I put down 329HP/340TQ with Cats, Corsa and an airlid. I had a minor banging problem that was fixed with a crow bar, none since.
As stated above, I think the QTP issues were just a bad batch. Can't go wrong with either.
Old 11-03-2006, 09:14 AM
98camaroLS1M6's Avatar
When was this bad batch manufactured?
Old 11-03-2006, 09:47 AM
Ya so all the QTP problems seem to come down to grinding the K member or bending the header, definately dont want to have to do that...
But you think with the QTP that it was just a bad batch and if i were to buy new ones i wouldnt have that problem?
Old 11-17-2006, 05:39 PM
radz282003's Avatar
I had to do a bit of grinding, but, it wasn't a big problem. It was difficult to conceed to doing that, for the price of those things, but, it didn't turn out to be to big a deal. They did offer to replace my set, but, I didn't want to have to pull them back off, wait a long time, and them put them back on, so, ultimately, I decided to grind.
My set was from around the beginning of this year, if I remember correct. Probably one of the earlier batches. My brother got a set from a later batch, and we had to grind, and he was prepared, as was I, so it wasn't a big problem either.
BUT, they make good power, and look even better, IMHO.
QTPs for the win!!!
Old 11-17-2006, 05:58 PM
n20stroker's Avatar
QTP gets my vote!!
Old 11-17-2006, 06:01 PM
CaMaRo67RS355's Avatar
QTP All The WAY!!!
Old 11-17-2006, 06:44 PM
blue01ta's Avatar
I think QTP's fitment issues came when they changed suppliers late last year/beginning of this year. I got my QTP/HVMC's early this year and had no installation problems at all. The HVMC's used to be about $1250 but when they changed over to the new supplier the price dropped $500 so a little fitment problems were worth the end result. Maybe they should've done a little more work on getting the headers right the first time but I believe they have them straightened out now. Plus they are polished and look great.
Old 11-17-2006, 07:08 PM
The1N_only's Avatar
Both companys make very good headers. I would say QTP's, but you have more options with kooks... too bad QTP's stopped making their 1 7/8's headers
Old 11-17-2006, 07:15 PM
BOONE's Avatar
Go Kooks, Qtps sucked for me. Long story. Kooks are quality every time. Its a obvious dicision. Qtp=????? Kooks=
Old 11-17-2006, 08:15 PM
SS DNA's Avatar
I love the quality of the QTPs, But mine sucked, The yare off the car and HOPING QTP would replace mines........
If anyone knows who to contact, PLEASE let me know.
Old 11-17-2006, 08:20 PM
The1N_only's Avatar
what kind of problems did you have?
Old 11-17-2006, 08:25 PM
transAm-98's Avatar
I've never had any problems with my QTP's . i've had them out a few times now while working on my car. And the install gets easier everytime. I don't have to unbolt anything and i've never had to grind anything. They have awesome clearance too. This is the first time i've every heard so many problem about them.
Old 11-17-2006, 09:58 PM
NiCks Ws6's Avatar
at first i was going with QTP's but after hearing all of the different stories, i just said im gonna go with Kooks. never heard nothing wrong about there headers.
Old 11-17-2006, 10:06 PM
KrazyDan's Avatar
they are pretty much the same design. When I bought headers, I went with the best deal. At the time it was Kooks and I couldnt be happier.
From what ive read, Kooks ypipes tuck up higher though, but a custom y is the way to go
Old 11-18-2006, 02:08 PM
just making a guess but, you think it has to do with the year of the car and the fitment problems that go along with them?
Wild guess
Old 11-18-2006, 08:16 PM
SS DNA's Avatar
Mines are rubbing on the K member bad. The passenger side one its basically resting on it. The driver side one its better but it rubs so bad on the steering shaft.
Old 11-18-2006, 08:27 PM
radz282003's Avatar
A little grinding on the K-member, and you'll be squared away.
Try to loosen the two 13mm bolts on the steering shaft, and try to adjust it down a bit. This will change the angle of the shaft, possbily enough, to where you will get better clearance. This worked for me also.
Good luck.
Old 11-18-2006, 09:40 PM
SS DNA's Avatar
Trust me, I tried everything. I ran them on my car for a while but I wasnt happy with HEAVY vibrations at stop lights or stop signs. My whole dash would ratle.
