Motor tear down? Power steering pump problem
Old 11-03-2006, 05:39 PM
95FbFormula's Avatar
Default Motor tear down? Power steering pump problem
I have come to a stoping point on my tear down I am working on the pass side accsesory drive bracket and I am having problems getting the power steering pump off. I have the feed line off that goes to the pump but cant seem to get any kind of wrench around the fitting that is behind the pulley Do i have to get a tool to pull the pulley off or is there some way i can get that fitting out of the pump I really dont want to cut it.
Old 11-03-2006, 05:41 PM
High on diesel fumes
thunder550's Avatar
You can go to somewhere like AutoZone and rent a power steering pulley puller. It's just a press-fit on the hub.
Old 11-03-2006, 05:46 PM
94Z28Joe's Avatar
I just unbolted the pump and presauded the pump to come off of the bracket and then removed the line. went back on with no problems also
Old 11-03-2006, 05:50 PM
well i have it unbolted from the bracket and I ended up cutting the soft line from the resivior. Its just the hard line wih the fitting right behine the ully that gave me problems I will go to autozone to see if i can rent a puller tho and see how that works.
Old 11-03-2006, 06:00 PM
94Z28Joe's Avatar
I took the hard line off after I unbolted the pump and removed it from the bracket
Old 11-03-2006, 06:03 PM
DropTopFireChKn's Avatar
i used a 3" ext. and stuck it in a hole that's cast in the pulley, after that it was easy to get it off
Old 11-03-2006, 07:01 PM
jm93camaro's Avatar
same here, pulled off the resevoir hose(didn't cut it) than persuaded the pump over the bracket and than removed the hard line. It will come off without pulling the pulley.
Old 11-04-2006, 03:46 AM
UnitZ28's Avatar
dont bother pulling off the pulley.. its not necessary
Quick Reply: Motor tear down? Power steering pump problem
