my buddys car's oil pressure drops to 25 psi under WOT!!
Old 11-03-2006, 09:45 PM
ninetres's Avatar
Default my buddys car's oil pressure drops to 25 psi under WOT!!
my buddy has a 1998 camaro and i took a ride with him and his oil pressure is completly normal at idle 40 psi...then he smashes it goes to about 50 psi then drops to 25 or so immeditaly... any suggestions? other then change the oil pump or is this normal for 98s?
p.s. he is using 5w 30 mobil 1.
thanks
Old 11-03-2006, 09:47 PM
Revelation Z28's Avatar
well the pump may be bad, or the strainer is clogged.
mine runs at 40psi when moving, and 22-25psi hot idle. 50psi cold start idle.
but 25psi is bad for anything above 2000rpm.
Old 11-04-2006, 12:44 AM
staringback05's Avatar
1st...drop the pan and check for any metal or damage....2nd clean the strainer...3rd change the pump....the pre 01s had bad pumps....had to rebuild my motor because of one of those
Old 11-04-2006, 02:40 AM
ninetres's Avatar
thanks
Thank you Mr_president/tondss for posting under my name on when you were at my house.
I take no credit for your grammar.
Old 11-04-2006, 11:41 AM
98boxer's Avatar
What oil filter is your friend using? I used to have lower oil pressure, but when i switched to mobil 1 oil filter, this helped to get better pressure. I also have a 98 camaro, and if I could i too would change the oil pump just for insurance, but so far so good, just keep an eye on the oil pressure that's what i've been doing.
