918 spring compressed coil gap?
Old 11-04-2006, 01:49 AM
mvvette97's Avatar
Default 918 spring compressed coil gap?
Just wondering if anybody would know what the gap should measure in the two top coils when the spring is compressed. I'm not sure if i have enough or not. They look close but they are not touching.
Old 11-04-2006, 02:01 AM
PREDATOR-Z's Avatar
Outside Diameter (O.D.): 1.290"/1.060"
Inside Diameter (I.D.): .885"/.656"
Installed Pressure: 130 lbs @ 1.800"
Open Pressure: 318 lbs @ 1.200''
Coil Bind: 1.085"
Maximum Lift: 0.625"
Rate (lbs/in): 313 lbs/in
Old 11-05-2006, 12:53 AM
mvvette97's Avatar
Coil Bind: 1.085"
Hmm, yea but should I have alot of gap between the coils with the cam I have or should they be mostly compressed?
Old 11-05-2006, 02:07 AM
Ls2Sonoma's Avatar
you dont measure a conical spring like that, the coils are the top are weaker than the bottom coils
Old 11-05-2006, 02:09 AM
mvvette97's Avatar
why do the bottom coils compress first?
Old 11-05-2006, 03:43 AM
PREDATOR-Z's Avatar
Just measure installed height with the proper tool. 1.800 it is.
Old 11-05-2006, 08:52 AM
vettenuts's Avatar
Upper coils are stiffer, lower coils collapse on top of each other taking out their effective mass for acceleration of the open valve. I wouldn't worry about it. As stated, check installed height, clearance to seal and amount of distance to coil bind. I think your original problems was the retainers or the springs and I wouldn't trust the Ebay vendor you got them from.
Old 11-05-2006, 11:21 AM
Ls2Sonoma's Avatar
just adding... its the other way around, top coils compress first. beehive or conical springs are known as variable rate springs because the smaller diameter coils (top) compress first, then gradually as the installed height decreases, the bottom coils start to compress adding more pressure
Old 11-05-2006, 11:38 AM
mvvette97's Avatar
sure hope so. I guess if ity does it again then it will get a dual setup. I do agree with ya about the first set of springs. I just wonder if they were fake or just crap
Old 11-05-2006, 11:39 AM
PREDATOR-Z's Avatar
Incorrect with beehives
Incorrect as well.
It is actually the opposite
Old 11-05-2006, 11:41 AM
mvvette97's Avatar
Incorrect as well.
I was thinking that also.
Old 11-05-2006, 11:50 AM
PREDATOR-Z's Avatar
Here is a good write up:
http://www.krcperformance.net/newcontent/beehive.html
