ignition relay problems, help!
i have a 2000 TA, an i seem to be having problems with my ignition relay, ive replaced it twice already over a 2 year period, i replaced it a couple weeks ago an it seems to be acting up again-i put the key in turn it an nothing happens, turn it again a few times an it starts, its an M6 anyone got any suggestions on what to check? thanx in advance for any help
What do you mean by "ignition relay" - the engine controls, cruise control, air conditioning relay under the hood? Almost sounds like an intermitent vats/key problem?
the ignition relay thats in the fuse box under the hood, i replaced it for the second time a couple weeks ago an it's starting to do it again, i put the key in turn it to start, nothing happens, turn it a few times again an it starts, i thought it might have been something with the vats too but my car is showing the same early symptoms that it showed before my relay went bad
I am having a similiar problem... I put the key in turn it and everything but the car comes on.. but I cant jump the starter relay to a power lead and turn the car on... wondering if my relay is bad?
