first gen brakes
the ls1 rear brakes bolt right up to the '67 axle tubes, you just need to run your e-brake and lines, of course. 68-69 you have to run two, left side backing plates, as the staggered shocks get in the way.
for the front, to run c5 or ls1 brakes, you need the drum hub, with the rotor over it, and a caliper bracket to hold the caliper. that's it. theres a guy on pro-touring.com that sells the brackets, laser cut, for $50, last time I checked.
oh, and you can get a nice one from speedtech, too. i forget who the guy on pro-touring.com who did it was.
here's the link
http://www.speedtech-performance.com...prod/prd51.htm
here's the link
is there a thread on this detailing the specific parts required for swapping 4th gen disc brakes onto a 1st gen drum brake equipped 10 bolt ?? i would need to replace the 15 inch wheels with 16 inch wheels?
sawzall wielding director
There is probably a thread about it on the www.pro-touring.com forum, but I am not really sure. Try searching LS1 Brakes on there. You should upgrade your wheels to 16`s. The 15`s will not clear, but a lot of the 4th gen guys grind the caliper for clearance so they can run 15`s at the strip, But be VERY careful if you grind the caliper I have seen people grind them too much and then the caliper breaks apart when they hit the brakes.
Originally Posted by billscamaros
i would pass on grinding the rotors down a bit; don't care for that idea much.
You will need to grind down (about 1/8") the front hubs, so the ls1 rotors fit over them. But thats no big deal at all.
Here are just a few links to give you a better understanding of what exactly goes on...These guys can explain it a whole lot better than i can.
Good info here,
http://www.geocities.com/torkerscamaro/torker.html
This is David Pozzi's site. Tons of info and templates for the front callipers.
http://www.pozziracing.com/12_corvet...es_on_fgen.htm
This is Jan Suhr's site. He's on this forum(LS1 tech) and he has a ton of info on the swap both front and rear, and a template for the callipers. A very cool car in Sweden!!!
http://www.protouring.se/
Ls1 calliper rebuild, in case you need it!
http://installuniversity.com/install...sity/index.htm
The super cheap way,junk yard hunting for the old stuff...but it works.
http://www.oldengine.org/unfaq/leadfoot/discs.htm
Hope this helps you, it helped me.
Chris P.
O, and you will probably want a set of these Cross Drilled Brake Lines. I hear they work excellent!!
you can get them at Kale Co Auto.
Here is there web site, and there are a lot of other great products that they sell, check it out!!
http://kalecoauto.com/index.php?main...&products_id=1
Originally Posted by 76LS1BIRD
I made these form the temp on pozziracing site.
They are 1/4" & for the LS1 brakes . Dale
Do you have the demension of the templet that you use, or better yet, do you have a copy of the templet you can post?
Thanks
Originally Posted by Tri5Nerd
Thanks for the info, but I don't see the dimension of the template on the pages.
Here are the ones I have found. I believe two of them are for the ls1 brakes (different styles) and the other is for the C4 brakes.
Hope this helps!
BTW, did anybody understand the brakeline pics I posted
Chris P.
Originally Posted by 67RSCamaroVette
how do you make them work? space them out with washers? i calculated that you need 1/2" thick material or something along those lines.
Did ya' look at Jan Suhr's site??? www.protouring.se
When you get there go to "Downloads". He has a very professional pdf of how he made his c4 brakes work. Defiantly worth reading!!!
Just to point out that the brakes I used are LT1s, Corvette C4 and Camaro LT1 89-93.
For the LS1 front calipers there is no difference as I understand with the brackets. For the rearbrakes the LS1 are a better option with the small parking brake drums. The LT1 parking brake sucks.
Jan
