Bottom of front fenders flaring out?
Old 11-04-2006, 04:24 PM
HowellSoccer88's Avatar
Default Bottom of front fenders flaring out?
I went and looked at my car for the first time in a couple weeks the other day (its being garaged for now) and I noticed that the bottom of the front fenders on both sides was starting to flare out. The bottom of the fender by the door is starting to come away from the car. If you put your finger at the bottom of the door towards the front of the car there is about a half-inch gap. I didnt have a camera so I am hoping my explanation will be enough for someone to let me know whats going on...any input would be greatly appreciated!
Old 11-04-2006, 04:26 PM
Tainted's Avatar
could have broken the bottom fender tabs
Old 11-04-2006, 05:06 PM
Brian2006's Avatar
Someone put it on the lift wrong. If the tabs broke and you can't bend them back into place, then you'll have to bend them and drill your own new holes
Old 11-04-2006, 05:10 PM
Hmm I see where that could be it but it hasnt been on a lift in at least 3 or 4 months and it just happened in the last couple of weeks. So you are saying that if I get under there, I can either pop it back in or drill new holes? If I drill new holes will it mess anything up? I dont want it to look like **** basically is my only concern...
Old 11-04-2006, 05:17 PM
Tainted's Avatar
you can ehat up the bas and bend them back down
Old 11-04-2006, 07:22 PM
Any more specific details on how to do this without messing something up?
Old 11-04-2006, 07:34 PM
Tainted's Avatar
lol damn sorry dude im bad sick w/ a cold and not all the way there today. the tabs have 2 bolts that attach the bottom of the fender to the body. the tabs often break and fold over. if you take a hair dryer or heat gun, you can heat them up enough to bend them back straightdown with a pair of plyers. if the metal tab is bent you can simply hammer it back. no need to drill holes or anything.
Old 11-04-2006, 07:58 PM
PontiacFan's Avatar
Check your fender tabs, to make sure they are pointing down.
Search 'lift fender tabs', or any of those words. Common problem from improper lifting. Whether it was yesterday or 6 months ago, ...
Old 11-04-2006, 08:09 PM
427TWINTURBO's Avatar
does not take much pressure to straighten the mounting tab on the body & the fenders will straighten right up-- have seen this many times
Old 11-04-2006, 08:48 PM
Tainted's Avatar
i gave him the remedy already guys, im sure he can figure it out
Old 11-04-2006, 10:56 PM
thanks fellas i will look at it next time i see it
Old 11-05-2006, 05:38 AM
SleeperZzZ28's Avatar
yup sounds like the good ol Discount tire mod
Old 11-05-2006, 09:54 AM
CAMAROZ28AQUINO's Avatar
mine were like this also, take a pair of vice grips and put it on the fender tabs close to the front of the car where its flared out and push the tab in, making the fender tab point straight down. I did this to mine and only took about 5 minutes.
Old 11-05-2006, 12:45 PM
blertawho's Avatar
mine were completely broken off. so i had to put some screws in the fender. i think there may have been holes already there underneath there, but im not positive. here are some pics.
results. dont mind the rocker, thats all healed up now
Old 11-05-2006, 05:25 PM
Jeremiah's Avatar
The first thing most people do is grab a hammer and beat the tabs back into place without unbolting the fender. Your taking a big risk of breaking the tabs on the fenders if there not allready broken by doing this. The best way is to remove the two bolts, bend the metal tab back into place and then use a heat gun to soften the plastic tab on the fender and bend it back into shape.
If you dont heat the fender tab chances are it will break.
Old 11-05-2006, 05:33 PM
Tainted's Avatar
but if the tabs are broken on the fender they can be glued back
Old 11-05-2006, 05:37 PM
Camaro Ryder KV's Avatar
de re tire in orland park illinois, did that to mine, a$$holes and they compensated by giving me a few bucks off a tire
Old 11-05-2006, 08:45 PM
blertawho's Avatar
that sucks, i got $800 from discount plus and i could have gotten more from them. they sent 2 estimates to corprate one for $800 (reparing my fenders) and one for $1300 (fender replacement). when they called me they said we have 2 estimates here would you settle for $800 and i was just like yeah not even thinking they might have given me more. i was just shocked that they were even going to help me out.
Old 11-06-2006, 10:11 AM
calz28's Avatar
my way of fixing it (done twice, kramer tire and tread quarters..bastards)
lift one side of car with jack
find a 2x4 about 3 feet long
find decent size hammer or mallet
on the lifted side place 2x4 on damaged fender tab
strike 2x4 with minimal force until fender tab is back into place
repeat steps on other side
p.s.
tabs are stronger than you think
my wife ran over something and crushed my drivers side tab
i put the car on the lift and used a chisel, hammer, screw drivers, crobars to try to repair it,
Old 11-06-2006, 10:13 AM
Quick Reply: Bottom of front fenders flaring out?
