11 Second Club - :-( 12.04 @ 114.5 Stock Internal M6 :-(
347fairless
11-04-2006, 04:45 PM
Well, I didnt get it today, maybe next time.
1.71 60 ft - 5500rpm launch on the Fikse's with 275/40 17 MTDR's
7.7 @ 90mph 1/8th mile
Full weight. 250lb driver. Maple Grove, PA
Kept short shifting 2nd to third like a jackass for some reason. I will be at every test and tune and track night from now till Christmas to try and get it. Shallow staging the second bulb helped alot.
Blown2000SS
11-07-2006, 08:39 PM
Nice runs. How was the 8.8 swap. Easier than putting in a 12bolt?
chrs1313
11-22-2006, 01:53 PM
wow 3900 lbs that is extremely heavy...might wanna get it weighted i bet you are a little lighter than that, probably like 3750ish if you weight 250...if not lower, nice times by the way
Magnet
12-07-2006, 08:54 PM
dude you need to do some weight reduction!! you could be on the SI list if you lost 700lbs like all them...lol, but rally its not hard to pull 200+lbs out of our cars and keep everything stock looking and working IMO
347fairless
12-29-2006, 07:18 PM
I'll check out some weight reduction when i get it back from the dealer. Bent the 3-4 fork.
New Spec 4 and Chrome-moly flywheel sucks for powershifting.
mattf2
12-29-2006, 10:22 PM
can you give some specifics on your 8.8 rear? I've heard good and bad about this.
mvonada
12-31-2006, 10:20 AM
soooo close! You will make it when you get rid of the short shifting/
347fairless
01-01-2007, 02:00 AM
What do you want to know? A good place will make a jig out of the stock 10 bolt, and drop a 8.8 pumpkin in. Custom torque arm mount with lava like welds,and a set of axles with chevy ends and ford splines. Good to go!!!
mattf2
01-01-2007, 12:10 PM
who built it for you? Cost? How's it holding up?
347fairless
01-01-2007, 07:57 PM
http://www.swarrauto.com/ built it for me. Cost me about $1000 and I gave him the 8.8 rear, gears, and tlock.
Been holding up awesome. I have a tiny leak on the drivers side axle seal, gonna have it checked out when I get the car back.
big dave
01-03-2007, 04:18 PM
you definitely have one hell of a combo. 345 rwhp BEFORE the longtubes is insane.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
