What size single with stock cube motor?
Old 11-04-2006, 08:52 PM
datsbad's Avatar
Default What size single with stock cube motor?
I am doing a stock cube LS1 , single turbo in a 69 camaro .
I was wondering what you guys think for turbo size(STREET CAR ) and if the edelbrock victor jr with a elbow and ford TB will be ok ?
This is a street car and I would like full boost by 3500 rpm . Also how much low end will I loose using the above intake ?
THIS ENGINE JUST HAS RODS, PISTONS, ARP BOLTS, and cam and LS6 style heads. Looking to make 750 rwhp
Old 11-04-2006, 09:56 PM
smokinHawk's Avatar
a 76mm turbo should fit the requirements.
Old 11-04-2006, 11:26 PM
Bird-Of-Prey's Avatar
I'm thinking a Turbonetics TC76 with the MPS wheel should work very well for you.
Old 11-04-2006, 11:47 PM
datsbad's Avatar
What is a TC ?
I know someone also recomended a GT47 ? Would that work also ?
and what about the intake, will i loose good low end torque?
Old 11-05-2006, 01:14 AM
obZidian's Avatar
again, a 76mm would do well. However, it all depends how much rpm you want to turn, intake, cam, exhaust, hyd/soid roller... etc.
Old 11-05-2006, 09:27 PM
datsbad's Avatar
I would say 6500 tops and hydaulic cam .
Old 11-05-2006, 10:54 PM
Originally Posted by datsbad
What is a TC ?
TC is a turbonetics unit that was designed by Jose of Forced Inductions and Turbonetics. A GT47 is a large frame turbo and really wouldn't work as well with a stock cubed motor.
Old 11-06-2006, 09:28 AM
LS1TECH Sponsor
DrTurbo's Avatar
Wow, a GT47 is a thumper turbo. no need for it unless you plan to spin that engine fairly hard and make HUGE power. A TC76 will make 1000crank hp and is a compact unit that you can fit without moving and eliminating creature comforts.
Old 11-06-2006, 11:58 AM
obZidian's Avatar
that turbonetic snail is pretty wicked. I had no idea jose got in on that one.
Old 11-08-2006, 12:21 PM
LivernoisMotorsports's Avatar
We have a GT42 76mm for sale if your interested.
https://ls1tech.com/forums/lsx-parts-sale/605404-gt4276r-turbo-ls1-cams-etc.html
Old 11-08-2006, 01:02 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,087 Likes on 716 Posts
So far, and take my results with a grain of salt, I am not seeing full boost by 3500 rpms with my 346ci + GT47-88. I had some valvetrain problems that might have skewed earlier results but I'm thinking I will need to spin the combo to 7200-7400.
Old 11-08-2006, 02:30 PM
RW99's Avatar
Maybe a little off the topic, but why not consider twins? Since you're already transplanting into the '69, you'd have flexibility on your install, and probably easier to just keep each side separate? Just a thought.
If you stay single my vote goes to the T76.
Old 11-08-2006, 03:09 PM
SuperZ's Avatar
I run a GT-42 76mm T6.Its works very well
Old 11-08-2006, 03:19 PM
ninetres's Avatar
T76gts FTW.
Old 11-08-2006, 04:55 PM
LS1TECH Sponsor
DrTurbo's Avatar
76GTS or TC76 would be the way to go. TC76 would be the cheapest.
Old 11-08-2006, 04:59 PM
LS1TECH Sponsor
DrTurbo's Avatar
You would be suprised at the crap that leaves here after being modified for production....lol
Old 11-08-2006, 06:23 PM
HellRaiser's Avatar
Whats the most power the 76mm can put to the wheels for a stock cube LS1?
Old 11-08-2006, 06:33 PM
Depends on which turbo you are talking about and what wheel you are using. Also depends on what your setup is. I would venture to say generally speaking somewhere between 750 - 1000 rwhp is possible.
Old 11-08-2006, 07:06 PM
HellRaiser's Avatar
So has anyone put down 850+ on any style 76mm? Just seems like the most I've seen is mid 700's I just wanna know if you can make more that with it.
Old 11-08-2006, 07:11 PM
motorbuilt's Avatar
Several of the turbomustang guys have put down near 1000 rwhp on 331/347 combos with a 76mm....and those were like GTS-76's and GT-42's etc....
If you step up to a S76 then you can maybe see 1000-1100 rwhp on that.
Quick Reply: What size single with stock cube motor?
